All my problems are solved!
I worked on bypassing the FDC yesterday and ran into a snag without time to fix. I ended up denting the brass fitting on the hydraulic head inlet when trying to reposition it that I couldn't use my original fuel line. (I was swapping the return and supply fuel lines to have enough slack for the FDC bypass).
Of course there wasn't anything available at the normal hardware and auto parts houses that had the right flare (at least, not in stock). By the way, anyone know if this is a standard JIC type hydraulic flare or something?
I resorted to using my make-something-work mentality and ended up using brass hose barbs with fuel injector line (rated for higher PSI than normal fuel line) to make a temporary fuel line from the filter outlet to the IP inlet.
No leaks, went for a test drive, and
HAD TONS OF POWER EVERYWHERE! I'm getting about 7psi of boost under load. I was going easy on it as I don't have an EGT gauge yet but all of my super-slow issues have been resolved (at least temporarily)!
Have to slow down on the project as I'm getting my M1009 ready for the Haspin rally this week and my wife has a list waiting for me afterwards. It's currently parked (as pictured) awaiting me to put on an EGT gauge, install my external brake reservoir, and other small items like that to get it ready for registration and road tripping.
FEELS AWESOME TO BE AT THIS POINT!
![IMG_1436.jpg IMG_1436.jpg](https://www.steelsoldiers.com/data/attachments/500/500756-39d83cb19b4d2db1430ec3ef119713a9.jpg)
