- 535
- 725
- 93
- Canton, PA
I just finished replacing all new rear axle seals, repacking the bearings, and cleaning up all the old grease. I replaced the cork piece which was not present when disassembling. I retorque to proper specs. After test driving the truck for about 45 mins, when stopping at the house that hub is the hottest Hub on the truck. There is no leaks after driving. What would cause the hub to be so hot. It's not so hot that it burns you but hot enough that I don't want my hand on it for long.
Mind you we live in the mountains and we use alot of braking. Could the brakes be causing the heat?
All the bearings were in good shape when we repacked them. Any help would be appreciated.
