- 60
- 0
- 6
- Bethlehem/PA
M1037 REAR SPRING CHANGE? ANY ADVICE OR PARTS LIST?
I did some research and found out that the upper rear spring perch and the springs are different in a M1037. They are 1 turn taller. I am thinking I can just add M998 rear springs and a spacer and maybe new shocks and I will be fine. I'd like to keep it as stock as possible to change back if I ever wanted to.
Has anyone done this? Is there anything I am missing about this idea? I am assuming I only have to drop the bottom swing arm to make this change.
Any help would be awesome....Thank you in advance.
