- 5,580
- 352
- 83
- DESOTO, KANSAS
Well I don't have this mounted on a trailer yet, but looking for a 20' two axle civi trailer to mount in on in the future for disaster response. I have had a MKT and a TFK but both really needed a large/mil (slow)truck to move them so have opted for lighter, lower one. I got a MFK set, (Modular Field Kitchen) that will be mounted to the trailer. It will have the MTV bows and long bed cover installed to cover it all and will be fabricated to rise up when in use. Thought I would share some of the up graded stuff that came in the 4 crates that made up the set.
This is GL's Picture
The 2 largest items are the serving steam table which holds 4 full size pans frame is all aluminum and manual states 1 2A burner will work, set came with 6, and 3/8 aluminum griddle which has the same 2 part frame.
griddle with SS guards up
Came w/ two new style ovens (been around 18 years) they are meant to have 2 stands under them. They are double walled convection style so the heat from the burner flows around the outside of the oven walls, no flame inside like a M59 range. I am going to mount a thermometer through the door for temps. They are called an Oven, Baking, Deck.
two vents on top for heat to leave
It came with 0ne T meal heater but I have a couple so will use them as the cleaning/wash sinks
Came with 2 heavy duty SS topped prep tables, that have a SS shelf that spans across the lower leg braces, top also has built in for can opener mount.
