- 661
- 106
- 43
- Broad Run VA
So we arrived at the Graves Mtn. Rally and after checking in, went for a short spin until the driveway I pulled into and could not back out. Fluids are fine. Levels good, smells/tastes good. Just no reverse. Had several other 5 ton owners take a look, but no go.
Now Sunday arrives and I pack up and head out ( Have to work tomorrow ). After getting out of the country roads, now have no 5th gear. Stopped several times to both manually vs. auto shift but no go. When I made it home it did shift into reverse but as soon as I accelerated it seems to pop out as if in neutral? Tried this several times as I back it into a space but could not get it to move enough to get it in. Looked at some old threads plus the tm.
Ant thoughts? Only obvious thing I was hoping was an o-ring or clogged port? But now with no 5th?
Could the selector shaft come loose inside?
Simp? 74M?
Simp? 74M?
