Glad hands replacement
Reworked LMTV
1,568
1,216
TN
Do replacement glad hands handles have to have the valve on them? My valve leaks.
simp5782
Feo, Fuerte y Formal
9,509
Mason, TN
No. Most of us on the 939s just use 1/2" shut off valves for water pipes from the home depot or other places that sell them. Glandhands are just 1/2" pipe screw on fittings.
NDT
7,436
Camp Wood/LC, TX
What is a "glad hand handle" on a FMTV? Simp assumed you were talking about a shut off valve.
Ronmar
8,326
Port angeles wa
The front ones are vented because the front lines feed into 2 way check valves on the service line and a regular check and a 2way check on the emergency line. If you have noticeable air leaking out at the front gladhand vents, you need to track down which valve is leaking back and fix it... If those are leaking and the gladhands get capped, air pressure will build up in those lines and it can hold a 2 way check in the wrong position which can interfere with normal brake operation...
