Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
not much help here on that question. I will give it a try
my guess is that it should fit since the floor pans lmc sells are all the same from 73 to 87. I think the cucv is based on the 82 year model
They should fit form the years you mentioned , the transmission tunnel is different between 2 wheel drive and 4 wheel drive , it shouldn't effect the seat.
Yes they do fit, I know this for a fact. On some of the early years the seat back is just a bit taller and it may hit the rifle mounts, the bigger problem is that on the 70s modles the seat belts came up thru the gap between the bottom and the back instead of having the plastic grommit thru the seat bottom.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
