Michael
- 24
- 38
- Fulton, MS
Now to try to add the videos. Getting an error that SS doesn't support mp4s.
Sent from my SM-G965U using Tapatalk
Your correct about the play. Since Turbo's spin so fast they need to actually be riding on oil. That is the main reason we need to let the engine idle after running hard to allow the turbo time to spin down. Most people who have never rebuilt or even been into a turbo will think the bearings are shot when they are actually in excellent shape. The true measure is if you actually see oil leaking past the seals. Or in extreme cases, bits of impeller vane or housing broken or scraped offI've seen some brand new turbos that had quite a bit of shaft side play. I don't know what the measurement is, but it's quite a bit just going by feel. My rule of thumb is look all the way around and see if you see any scrape marks on the housing, or if you can force the fan to rub the housing by hand. Also, I've seen some that were making pretty good contact with the housing, and still not leaking a drop of oil.
From what I've gathered, oil on the exhaust side is often "Slobber" due to the engine not being put under load often enough to force the rings to seal the cylinders well. It's oil on the compressor/intake side that tends to be more indicitive of bad turbo seals, and is also much more worrisome, not only due to the possibility of turbo shrapnel hitting the cylinders, but also if the seals leak badly enough, the oil can become an additional/alternative fuel source, allowing the engine to "run away" on us.You guys are making me a little nervous with all this talk about turbo shrapnel destroying the engine, so let me ask a dumb question. Can some kind of screen be installed to catch any flying debris?
Also please tell me if there is anything noticeably wrong with my turbo. Is the turbo leaking oil or is this normal exhaust blow-by or is it supposed to be there whatever the reason? Thanks.
At one time there was an attempt by manufactures to prevent debris from entering through the turbo. It didn't work. So the only thing you can do is be vigilante and check your engine whenever you drive it. Hear a funny sound that doesn't go away ? Check it out.You guys are making me a little nervous with all this talk about turbo shrapnel destroying the engine, so let me ask a dumb question. Can some kind of screen be installed to catch any flying debris?
One more thing please, that short hose connected to the front of the turbo from the air cleaner looks like it is crumbling. Could pieces of that get sucked in to the turbo and engine? It seems like it could.
OK thanks Rusty, do you know who sells the one I need? I have seen that hose at the regular places Big Mike's etc. However they look like the same laminate type hose I have now. Thanks.As for that hose. Yes, replace it with a good Silicone Turbo hose.
There are several sites that sell silicone "turbo hose" . It's a very common size. Just buy a foot of it and cut off what you need. Keep the rest for spares.OK thanks Rusty, do you know who sells the one I need? I have seen that hose at the regular places Big Mike's etc. However they look like the same laminate type hose I have now. Thanks.
