- 44
- 8
- 8
I went to my old unit today and was lucky enough to have one of the mechanics put the -10 Manual on a disc for me. It is over 1500 pages. I think it is too big for email. Any suggestions on how I can make it available to the A1 guys?
The A0 manuals are thousands of pages too.The soldiers are very frustrated that they can’t get a hard copy either. They have to access it from the computer that rolls around on a cart. They could print them up but the manuals are too big and would exceed their budget for ink and paper.
makes since that both the A0 and A1 both incompass thousands of pages.When they went to the A1 with C7 engine the TM was then accessed through the diagnostic software. The manual I have was pulled from that program and is a PDF. You do not need the software to access it. The A0 version is a regular printed TM or pdf.
Ah, so only the troublesome part is different.About the only thing of major difference between the A0, A1, and A1R is the electrical system. Axles, frame, body, driveshafts, cooling, suspension, and steering are for the most part the same.
suspect you will find that each section/chapters/folder.... however it is done... is 1500 pages. you may even find that the images, drawings etc. are held in separate folder but hope note. Example..... each A0 TM is close to 1500 pages. some are larger.I was side tracked due to the issues I had this weekend with my trial run of the truck. I have drill this coming weekend so while I am at the unit I will attempt to upload the manual. It is around 1500 pages. I will try and separate it into smaller files to get it loaded in the TM section here. I will post when I have completed it for you guys. Thanks.
