trouble getting spare parts to head to rally!
profo
75
jeanerette,la
I have trying for over a week to get correct parts (Water Pump,Idler Pulley and Belt tensioner)for my m1078A1 LMTV with 3126 cat engine number 7jz00087, to no avail, the CAT computer at dealer shows a water pump that takes a vbelt my complete engine runs off of one serpentine belt can someone direct me into the correct part numbers so I can just go to cat dealer and say i need these part numbers or is someone on SS that has these parts.
Thanks Marty
Suprman
707
Stratford/Connecticut
I have complete v belt upgrade kits for the 3126. Maybe your truck has the kit. I can try to see if there is an inv in the kit tomorrow. Whats your truck serial number I may be able to look that way too.
profo
75
jeanerette,la
9A139BA4-A001-45B2-814C-E0FF2417CE0D.jpgD10AC2B4-1F5A-462B-8919-EF3F9064ADE7.jpgE609FF53-2CB1-41E4-9075-157656398632.jpg
I ended up pulling everything getting numbers off the parts crossing them i here they are;
This is for the 3126 cat with all serpentine belt system!
Belt K080775 original mil part only use a K080774 napa 77.5" long 8 groove!Idle pulley-cat 173-1498 use napa 36231Belt tensioner - dayco 220-1209 use napa 38550Water pump 203-6093 use napa RW4017X
Reworked LMTV
1,571
1,217
TN
Karl kostman
922
Fargo ND
Profo your truck really is beautiful, I never realized there was another color than OD? And it looks **** good!
karl
profo
75
jeanerette,la
Think it's color is 2015 or 2016 Toyota Tundra don't remember year would have to look at paint can! I saw the color on a truck when I was cutting grass one day and said I like that color!
coachgeo
3,553
North of Cincy OH
... I ended up pulling everything getting numbers off the parts crossing them i here they are;
do you mind spacing and or punctuating some way so this is more readable. Hard to tell what goes with what with it all run together. Also if those are intended to be links they do not work.
Much thanks.
