- 152
- 26
- 28
- Franklin, TN
Has anyone had an issue with a grinding type noise with field flashing either an 802a/803a?
I am working on a 803 that has no voltage or hertz.
When I hold the start to flash I get a grinding type noise. On the S1 #7 I get 24v for a blip and nothing happens. Also, using a good field flash relay from a working set.
I am using a good working VR1 from a working unit and went through the test procedures and don't get any voltage when performing procedures H & J.
I also tested the speed sensor and get no voltage during start up. This 803 does not have the quad mod and has 31 hours the meter. I took the cover off the the back of the generator head and saw nothing exciting on the exciter section. Everything is real clean. I started the TM procedures for testing the exciter but the CR connectors are a bear to get to.
I have spent quite a few hours going through the TM and trying to figure it out but I am at a loss right now.
