$1.58 tubing finally fixed my doors. No more slamming.
rodent
Denver, CO
Ever since I bought the truck, I've always had to slam the doors REALLY hard. I know the plastic bushing was missing form the door strikers but I didn't think it would make this much of a difference.
Went out and bought some 1/2" Pex tubing in white at Home Depot for $1.58 for 5 feet. Cut off 3/4" and put it over the door striker on both sides.
No more slamming of the doors!
How to video:
https://www.youtube.com/watch?v=yS_eRtSdw-A
Another option is to buy new strikers for $11 each.
Tinstar
2,503
East of Edmond, Oklahoma
Saw the post and was also having almost same issue.
Always worse when windows rolled up because of air pressure inside.
Already had PEX on hand in red and blue. Used Red.
Took less than 10 minutes
Problem solved.
It will never close like a Cadillac, but it’s 100% better.
Worthy of a stickie.
cucvrus
10,505
Jonestown Pennsylvania
Been using 1/2" rubber hose for years. And my Cadillac has a different striker system. Or as some say Ratillac. long story but I had a few mice up in the headliner and A/C vents when I bought the car. They were living high class rent free until the eviction came. Have a great day. With the rubber hose you have to remove the striker this will be easier for those not wanting to adjust the door.
Hulkdeisel
SW/OH
THE BEST FIX EVER... did it yesterday absolutely worked perfect no more slamming doors! Nice call whoever thought of this. Only works on post type striker tried on my 76 Scout..no beuno :x
Recovry4x4
LLM/Member 785
1,824
GA Mountains
Several years ago I bought a box of 25 factory made striker bushings. It was less than $10. Still have a few left. Will switch over to pex when I run out.
D6T
536
Vermont
I wanted to post a huge “thank you” to rodent for this thread. Ever since I read the last few posts, I’ve meant to try this trick. Today I finally got around to buying the tubing and the result was astonishing!! My driver’s door closed perfectly for the first time!! Easily and relatively quietly with no slamming or repeated attempts to close.
[thumbzup]
Tinstar
2,503
After 8 months, the PEX I installed isn’t showing hardly any signs of wear.
Definitely a must do item if factory bushing is missing.
Keith_J
1,328
Schertz TX
PEX is tube, PVC is pipe. 1/2" pipe has an ID of 1/2", give or take. Tube is based on OD. PEX is a much tougher polymer and has good lubricity. PVC pipe has calcium carbonate powder in it, causing more friction.
Twigiestdrip
FL
Do these pex tubes come in different hardness levels? The ones I installed only a few weeks ago started to show the same wear marks that the original studs were showing. I have to keep rotating the pex in order to give the latch a fresh surface.
Tinstar
2,503
PEX is all the same I believe, just different colors.
I’ve had mine installed for over 8 months and hardly a mark on it.
Have you adjusted your door post?
