Jakelc15
- 36
- 28
- Hanover Pa
This company makes obsolete wheels. They have some that fit the deuce. I was thinking of putting Radials on a couple trailers.
http://www.wheelsnowinc.com
Those were the guys I got a quote from. It was like $200+ per wheel at the time. Replacing all 11 plus tires was gonna be a bit much!This company makes obsolete wheels. They have some that fit the deuce. I was thinking of putting Radials on a couple trailers.
They're pretty rare. They would be tough to find as those vehicles are LONG out of production, and they were an oddball in the first place.Wow. Thats a lot of $. Junkyard or custom hubs might be cheaper
Your right about the tires and rot. All the tire manufactures went to a "cheaper" softer rubber compound to "help" with road handling. All it really did is make everyone have to buy tires more often. Some of mine that are NOS from the 1970's (and kept inside) are still in great shape. Others I bought a few years ago are already showing side-wall cracks. So from now on any tire bought will have crappy wear characteristics. So having a modern tire size (for availability reasons) becomes even more important.What was or is the asking price of the 11 wheels and tires? And where did you come across them? I am leaning toward the 22.5's for the long run tire availability. I have watched road side tire changes of the 22.5's with one guy that knew what he was doing and with the proper hand tools completed the task in a few minutes on the roadside of I-5. I also have had too many tires with great tread fail dramatically due to age of the tire, and normally doing extensive body damage as a added expense that can often cost more than the darn tire. I don't see how 395's could last a lifetime if the rubber rots and the tire disintegrates. Perhaps I am missing something but based on my life experience, tires (and other rubber items) are one part that does not fare well in the passing years regardless of the numbers of miles. Moisture inside the tire is like a cancer that seems to destroy the tire with little outward signs. Tires filled with dry nitrogen helps but unless that is available all air compressors pick up moisture from the air, or worse, oil from the compressor crankcase. Both will attack the rubber and given time do extensive damage that you just don't see until it fails. As the supply of NOS tires gets older, this will become a bigger problem. Don't get me wrong, I have been a penny pincher my whole life but in doing so I have found doing something correctly is normally the least expensive when "real life" is factored in.
Wrong side...I'm just above NY state.cattlerepairman, Where in Canada are you? I moved from So.Calif. about 5 years ago to Washington State.
One company I found for new wheels is www.wheelsnowinc.com. which the one I believe you are referring to. I have considered the MRAP and adapter plates but 395's aren't cheap and the available stock is getting older and there are tread patterns for the 22.5's that look real good for the Deuce.
That should be on the T-shirt! Sums up the hobby!Perfect fit, not time consuming, cheap. Pick any two! You won't get the third.
Sent from my SM-T560NU using Tapatalk
These are 11R22.5 wheels and tires on a friends truck. Looks almost factory!
