daveiaff
- 11
- 8
- Pittsburgh, PA
Rebuilt for 12v or 24v ?I think I remember RWH here on the forum in a different thread mentioning something about having the wires on the IP hooked up correctly.
you might want to double check that or drop him a PM.
Or if your lucky he will see this post and offer a few suggestions.
BH[/QUOT
Yes the top electric cut off and idle were rebuilt with injector pump Thanks
Just get Rotella. Don't buy a new tester. Just do the test with what you got and see what happens.I'm looking for a better compression tester to borrow, and thought about the oil trick. Any particular type or weight.? Thanks
Well saidCompression is good initial, but leak down test is what is needed now.
The oil trick is only to determine condition of rings. Which you know are toasted.
The question is what is each cylinders psi compression? Is there only one at 60 psi? Are they all within 5-10% of each other? High low doesn't mean much.
Also the odo mileage doesn't mean ****. They go bad all the time and sop is to replace with a new unit with 0 miles.
Also are you able to replicate the knock? If so I wouldn't even tear down this engine. Get a running long block, and send this one in as core.
