todds112
- 5
- 18
- Teton Valley, ID
Need some advice on a total cooling system flush.
I removed several of the small hoses and drained the coolant. Opened up the drain cock on the bottom of the radiator and drained all that. Pulled T-stat housing too. Put the hose with running water in every open hose and let the water run for a long time, until clear. Drained radiator totally. Left everything drain for a while and re-assembled hoses and T-stat.
Put in new Anti-Freeze, first straight (1.75 gallons), then 1:1 mix of anti-freeze and distilled water. I let the truck run with rad cap off for a bit. Buttoned it up and took it for a ride to open the T-stat (would never get hot enough idleing to do it). Removed the cap (after it cooled) and found the new coolant rusty and very weak. I figure there was some water hiding in the system somewhere and diluted it.
So I guess I'm draining the radiator again. It there any way to get all the water out of the system? Do I just fill it with water only, drive, drain and repeat until it stays clear?
I didn't know about the coolant drain on the rear right side of the engine until a few minutes ago. I'm assuming I should open that too and just run lots more clean water through it.
Any advice would be greatly appreciated.
![0[2].jpg 0[2].jpg](https://www.steelsoldiers.com/data/attachments/512/512516-951821651b8e93f1897b795759fef0e4.jpg)
![0[1].jpg 0[1].jpg](https://www.steelsoldiers.com/data/attachments/512/512517-ce4f3b39987bea76b6009eb1b407fc74.jpg)
