welldigger
- 15
- 38
- Benton LA
That's definitely the steering box leaking. You can see it running down the inside of the frame.
Run by a John deere tractor dealership and pick up 4 tubes of corn head grease. You will use 3.5 tubes to fill the steering box.
Pull the drain plug on the bottom of the steering gear. Then you will need a Zirk fitting and a bushing. I think 1/8 by 3/8. Someone correct me of I'm wrong on that.
Allow remain gear oil to drain from the steering gear. Then thread the bushing/zirk fitting combo into the bottom hole. Then pull the fill plug on the top of the steering gear. Grab a grease gun and start pumping the cornhead grease in from the bottom until you see it coming out of the top fill hole. Then reinstall both plugs. Your steering gear is now leak free and always lubricated.
