About a year ago I had the fuel injector pump replaced on my 5-ton NHC250 because the truck was barely running and had a minor leak at the injector pump "weep hole". Now it's running bad again with a much worse leak at the weep hole on the rebuilt pump. The truck probably has less than 20 hours and 200 miles on the replaced pump! Any thoughts other than the obvious, being replace the darn thing again at the tune of about $2K? thanks!
