crazzyrman
I have a 1986 hmmwv that the heater blower motor died it has the round output. Do the newer heater blowers with the rectangle outputs just bolt on in place? I can figure out how to modify the output to fit the round tubing.
I can find the newer style with the rectangle output easily but the older style with the round output I can't find.Originals are not hard to find.
I have replacements
Bed rail height may be a tiny bit too high. Might need something like a couple of 2"x4"s laid cross wise in the bed to give good clearance. The CUCV Trucks had a tie down system for carrying the shelters. One crossed the front of the bed with a hoop at each side with long bolts and sleeves going down through the bed and into the cross brace of the bed. At the rear, sort of the same thing was done, but with no bar crossing the width of the bed.Also,
Am going to attempt to mount shelter to a 2005 Silverado 2500 HD 4X4. Any thoughts?
They didn't die at the same time but both died while I was having an overcharging issue that I finally got resolved & now I'm trying to fix all the other stuff I burned up while still running the truck.Did you heater motor and your windshield washer die at same time? Do you have electrical gremlins?
You need to check power to plugs and switches, and maybe also look for surges in current.
MH), YMMV
So if heater is now OK with cleaning, why are you so sure wiper motor is not salvageable?They didn't die at the same time but both died while I was having an overcharging issue that I finally got resolved & now I'm trying to fix all the other stuff I burned up while still running the truck.
