MEP-831A Oil Pressure Sender Suggestions
kloppk
4,202
Massachusetts
Looking for suggestions for a oil pressure sender (not a switch) for a MEP-831A.
1/8 NPT, reasonably priced, with either a nut/bolt terminal or spade connection.
Resistance of sender not critical.
AfghanVeteran2010
29
Odessa/Texas
I would go with the same one thats on the MEP-802a, Mep803a. They are available through a few suppliers. Search "DATCON OIL PRESSURE TRANSMITTER PART NUMBER 02504" The one listed on eBay looks like a good deal. Hope this helps.
Part numbers for the oil pressure sending unit.Part number: 02504NSN: 6620-01-128-3053SMR Code: 16476
kloppk
4,202
Massachusetts
Yes :cool:
Working on a unit that combines the Governor Controller with the Remote Start and adding Oil Pressure and Engine Temp. sensors.
glassk
Hampton, GA
Do any of these look like something you are looking for?
about ten sending units and eight gauges, four pressure,...
smokem joe
68
Green OH
I had found a low cost alternative for the 831 sending unit. It was from the same company as the OEM. I don't remember the part number off hand. A search may show it as I listed it here as a couple other people needed them.
kloppk
4,202
Massachusetts
I found the thread. It was about the Low Oil Pressure SWITCH.
I'm looking to add a Oil Pressure SENDER to read the actual oil pressure.
kloppk
4,202
Massachusetts
Ordered a couple off of fleabay today.
Demoh
26
St Pete, FL
I like the idea of using the same P/N as the 802/803 for simplicity, as long as parts availability is there. Im questioning the complexity of the mounting of that big thing though and if through a hose like the 802/3 the costs would be higher.
Best of both worlds would be to find a small lightweight sender that has the same sweep/values as the 802/3 so there are options.
Just ramblings here though.
kloppk
4,202
Massachusetts
I just put a mechanical gauge on one of my 831's. Unfortunately the 802/803 sender won't work. aua
Oil Pressure at startup is ~125 PSI and Oil Pressure when warmed up is 80 PSI.
Looks like I have 2 spares senders coming for my 802..
Have a 150PSI sender on it's way to try this weekend.
