Last weekend did not go as planned due to the sup-tropical storm in Florida...we received a lot of rain from the edges of the storm and our red Tennessee clay turned into jelly. Even the Cat was sliding around. We did get quite a bit of dirt work done on Friday with the Cat and Ford. The 816 batteries also gave us fits
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
, turns out they were low on electrolyte (probably from being sloshed around while driving on multiple trips from home to property) SO we pull started it with the Cat
![Banana :naner: :naner:](https://www.steelsoldiers.com/images/smilies/banana.gif)
. No pictures sadly we had our hands full between Dad and I but she fired right up. never had an easier starting truck.
Quick question for anyone with an 800 series truck, I noticed I have an extra set of cables in the battery box area, is this for a 4 battery set up?
We are going back down in June with topped off wrecker batteries, a lot of fresh diesel and hopefully picking up a replacement rear drag winch on a long weekend to finally build our structure for the equipment and probably gravel the driveway. More pictures to come.
The crane truck will be used quite a bit to help with that, it will be a 22ft x 26ft structure using a heavy military cover I got in trade as well as a ton of 2x4's, 2x6's and 4x4's to make a frame. Life is so much easier with a wrecker around, best money I've spent so far in building our cabin and developing our land.
Once its under cover I will be cleaning it up, fixing a few things and probably building a small extension for the crane to lift roof trusses...I am working with a crane company to help identify limits of whatever I come up with (no more than maybe 500 lb. lifting capability). I will share plans on here as well!
View attachment 730151View attachment 730152View attachment 730153View attachment 730154
