Garagefull
- 45
- 18
- Reno Ohio
I struggle with mine and it only has a zero rate and add a leaf in the back. I need a platform to see in the top boxes.View attachment 751685 as you can see.. sitting pretty tall for actually using it.The xzl's are even taller than these 37's.
Open any dictionary, to the Ds. You will find a word with definition "to avoid". That word is Dodge
It's only a 241. Generous Motors used them too. The joy of the Dodge case is the fact that it has a fixed rear yoke. Can run without the rear driveshaft.
I agree. Fortunately, the transmission being New Venture Gear is only part Dodge. Since New Process made the case, I guess it's close enough, it was a Chrysler company. I still hold hope that it will be a good combo.Open any dictionary, to the Ds. You will find a word with definition "to avoid". That word is Dodge
This sounds like you'll have a real good hi-way rig ! The NP241 isn't that bad of a transfer-case, and the NV4500 is a pretty good transmission. Not as strong as that SM465 your replacing, but strong enough.It's only a 241. Generous Motors used them too. The joy of the Dodge case is the fact that it has a fixed rear yoke. Can run without the rear driveshaft.
That's what I'm figuring. The truck tows very little, barely has enough power to hurt itself so the 4500 should be okay. As long as I keep everything tight, the 241 should survive as well. I haven't measured the length difference but either way, I'll mothball the original driveshafts in case the 465 goes back in.This sounds like you'll have a real good hi-way rig ! The NP241 isn't that bad of a transfer-case, and the NV4500 is a pretty good transmission. Not as strong as that SM465 your replacing, but strong enough.
I think you said Dodge NV4500? If so you may want to verify it has the upgraded fifth gear nut. While it tends to be a problem only on the HD 4500 (with the larger input, used behind Cummins motors) all the Dodge 4500 had incorrect spline geometry on the fifth gear, causing walking and eventual loss of fifth gear retaining nut.That's what I'm figuring. The truck tows very little, barely has enough power to hurt itself so the 4500 should be okay. As long as I keep everything tight, the 241 should survive as well. I haven't measured the length difference but either way, I'll mothball the original driveshafts in case the 465 goes back in.
A fellow Dutch member might have one. If he does not have it, I will be in contact with you! Thanks.I have a few of them. I can send you one.
Here are my notes I've compliled. I do have the Dodge gas version. I'm also aware of the 5th gear issue, I need to educate myself a little more on that. This trans and adapter plate were more/less a gift from Microjeep. I think it will be perfect for my truck with 4.10 cogs.I think you said Dodge NV4500? If so you may want to verify it has the upgraded fifth gear nut. While it tends to be a problem only on the HD 4500 (with the larger input, used behind Cummins motors) all the Dodge 4500 had incorrect spline geometry on the fifth gear, causing walking and eventual loss of fifth gear retaining nut.
The dodge has the higher first, and with my truck, (3.42 axle gearing) I really don't use it that much, but second is also higher, to reduce the second to third split. Mine is the GM mid version (smaller input bearing retainer, no synchro reverse, but gear ratios are same as dodge and later GM) with my use, I really should have waited for the early super low first.
The 241 is as strong as the np208, whether the Dodge or GM 88-91 square body version.
The nv4500, without an adapter plate is 1/4" longer max. I think machining makes up the differences, because mine was spot on same length as the SM465 I replaced. Although I have seen some photos online where the cases are up to 1/4" off.
Sent from my SM-S920L using Tapatalk
That is how to get things done, LIVE in your shop!Brought the 6.5 inside. It sits in the living room now (house isn't habitable yet).
Right now, I've set my mind on keeping the CUCV belt system. Removed alternators, power steering pump and brackets from the 6.2. Found one broken bracket.
Like to see a pic of that. Considering one for my junk.Installed John's CUCV winter front today on the M1028A2
http://www.jatonkam35s.com/cucvwinterfront.htm
Quality cover as with all his products!
Thanks John
Tom
I knew I should have taken Pic's.Like to see a pic of that. Considering one for my junk.
