davidkroberts
- 24
- 38
- west tennessee
Hi crew,ive got a strange problem with a M1009 picked up. When i got it the #2 altenator's two wire plug was melted at the alternator and the wires were not connected. The alternator also was smoking whenever current was put to the truck running or not. The Gen1 light lights up when the key is turned on and stays on when its running.
I replaced the #2 generator and fixed the plug and am not having any issues with it anymore i think.
Gen1 wasnt engaging and had no power going to the 2 wire plug. I fixed it by wiring it directly to the firewall plug block where the wiring diagram says it goes.
Before i found the wire not being hot I had replaced the Gen1 altenator. i ran a jumper wire from the Gen 1 alt hot post to the plug which was probaly pretty dumb looking back on it. Once i figured out that the altenator wasnt the problem i replaced the old alt and tested t with thejumper wire. The battery gauge never read in the green but just barely. Later duringthe test (still on the jumper wire) the Gen1 light came back on. Bu it worked for a half hour before coming back on and stopping charging.
Did I burn out the alt with my jumper wire stunt (likely)? Is something else going on. I am going to get another alt tomorrow without my stupid stunt with a jumper wire.
I am not very good with electrical stuff and could use some help.
