jimm1009
- 71
- 48
- Louisville, KY
I purchased by M35A2 W/W from the last owner over in Texas.
Got it 300 miles down the road and the truck started acting like it was lacking power.
Pulled over to put more diesel in as the last stop was 1/3 gasoline and 2/3 diesel.
Some trucks don't like gas and the lack power with gas in the tank so that was my first idea.
Anyway, I filled it back up with pure diesel and noticed smile coming out from under the truck.
Well it was from the right rear brake drum/hub.
I cooled it down with air and then some hot water and moved it 100 feet to an area where I
could park and leave it IF required. I am not sure at this time but I suspect a malfunctioning
brake mechanism or wheel cylinder.
I am going to make the 200 mile trek back up to the truck with one set of new bearings/races, locking washers, grease,
brake fluid, and a new wheel cylinder. Obviously will be taking a jack, jack stand,
and other tools.
What I need to verify is the bearing nut socket is an OTC1907.
I doubt that the bearings are bad but I never remove a hub without repacking the bearings
and sealing it up tight. The nut torque is always based on a freshly packing set of bearings
so this is my way of ensuring the torquing procedure is correct. Putting new bearings in with fresh grease
will be easier and cleaner than trying to clean and repack the existing stuff.
I also need to know that size wrench is used for brake adjustment and if anyone knows what size pipe thread
the brake lines are a the cylinder that would be good too.
This truck has MRAP tires and wheels on it so removing a tire is ok but if I were needing to load it up for tying up
that corner and disconnecting the rear driveshaft, etc., that would be impossible my myself.
I have changed drums, hubs, wheel cylinders, and shoes before on other M35s so I have that experience under my belt.
I will also take a pair of good used shoes with me as I anticipate that the ones on that corner are "toast".
Supposedly the last owner repacked all the bearings and installed new seals about 600 miles / 3 years ago.
Jim
and other tools.
Jim
