I might try bolt cutters for the bead, that way you won’t bugger up your rim. Just a thought.You need some OJ and to take a rest! I wondered how I'd get a shredded tire off of a wheel and the only strategy I could think of, was to use a cut off wheel to cut the tire near at the bead in several locations so I could pull it off the wheel. How did you do it?
Todays chore was 14s off and 16s on my 923A2.Wes just looking at all you do in a month I need a rest and long vacation.
As in dish soap? I can see it being harmless to sleeve seals but does it actually get the gunk out?Cascade flush works excellent.
Yes. Yes.As in dish soap? I can see it being harmless to sleeve seals but does it actually get the gunk out?
In the early days (2000), my unit had this MOC in a box. Originally, it was designed to be towed using artillery mobilizer wheels on each end. Unfortunately, it was too heavy and the mobilizer hydraulics often failed and in a very unsafe manner, so we put the MOC on a low boy and just kept it there. We towed it with an old, International single cab tractor. Man, that thing was feeble.Replaced the stock civi brake lights with M series lights. Also added an ID bar.
Which Gabriel's did you use? Mine have been on for over a year now.I *FINALLY* got the chance to see about changing out my shocks for the Gaberials. NO GO!!!!!!!!! The stud mount steps up in size, AND the "stroke" length is wrong, with full compression being the biggest issue, as in NOT enough of it. Crap. I also took a drive on the dark side today.....
Marine corp only. I don't know the exact production but maybe 20 to 50. There is a TM on it. It is an Altec setup though.Jeebus, when you have a blow out, you don't fool around.
Is this truck extremely rare? I Googled it and couldn't even find any real images of that model, just civilian trucks and earlier military TMT's. It looks very interesting!
Why the big purge?Got rid of one more so the grass will grow better and down from thirty trucks to six.
