- 104
- 43
- California
Greetings all.
During the the process of getting my EUC approved I have been doing a lot of reading here. Always amazes me the amount of knowledge and helpfulness. I will post in the transportation section regarding getting the truck out west but can safely say that getting the truck here was easier and quicker then I had imagined. Joey from United Sates of Freight was awesome from the beginning to the end. Driver showed up and we replaced the batteries and got the truck off before the wind and the rain set in. So thanks to him.
Truck is the standard issues 1078. Once the new batteries were installed it started right up and built pressure. Used another truck to help it off the trailer and on to the ground. The only issue I can see currently is that the transmission does not engage. Controller lights up and displays a zero. I can function Mode on and off but ti will not engage forward or rear gears. I pulled the code of the controller and it look like D1 43-26 is the code. However looking at the Allison codes It doesn't seem to mention a 43. When I get back to the truck I will check connections. Hopefully locate the connection on the tranny to see if everything is OK. ALso lights dont seem to work and cant seem to unlock the lights to allow them to come on.
I have had Unimogs (1300) in the past and am also into Land Rovers but have always wanted to try one of these trucks out. And like a lot of others, I will be building a camper as soon as I get the truck up and running.
Once again, Thanks to all who contribute,
Blair
Blair
