Over
- 6
- 18
- Cave Creek AZ
I have a M923A0 that I used to haul water. Slowly last year it needed a bump in throttle to keep idling at lights. It slowly got worse then I parked it. This year I pulled the fuel filter which had crap in it. Cleaned it all up, new filter, new line from tank to injector pump but still wouldn't start. Would only run on starter fluid. Pressurized tank and got good flow to pump and no leaks. Unhooked pump outlet injector line and noticed just a oozing of diesel out of it when starting. Also checked shutoff valve. Finally figured maybe the pump is bad as even when starting on fluid just an ooze of diesel on the injector pump outlet. Well...I pulled a pump from another known good runner M923A0 I have and installed it. Primed good, pressurized no leaks and flow out of large return line. Still wont start!!!!! Any thoughts?
