Troop seat?
Morc66
Virginia
When I purchased the M35 A2, it came with troop seats, but they appear to be off a different vehicle, they are shorter than the bed and bolts/mounts etc do not line up with the posts on the bed. The only identifying mark is a faded label on one piece with the following typed on it:
Pack#3.
1 Ea RH SEAT 10899218
1 EA RH BACK 10899202
I've tried to google the info as well as search some parts sites but having no luck identifying the correct vehicle,
Morc66
Virginia
I'll see what I can do. They don't appear modified, made from plastic of some sort, no apparent cuts. Basically consit of several slats, with fold out 'legs' along one side and a flat 'hook' on what I assume is the back side. The leg's do not lock perpendicular to the 'seat' part but can be folded out level with the 'seat'. I'll run over to the garage now and try some pics.
porkysplace
1,496
mid- michigan
Pack#3.
http://www.parttarget.com/
Both numbers comes back to a 5 ton extra long wheel base ( M927 , M928 )
http://www.parttarget.com/2540-00-860-0520_2540008600520_10899218.html/-7E350634-3BD7-4D30-A0A2-CB2D7F662543
http://www.parttarget.com/2510-00-8...02.html/-7E350634-3BD7-4D30-A0A2-CB2D7F662543
Scar59
42
Mt. Eden, KY
Yep, incorrect part for the M35. That is one half of a side for an extend bed 5 ton. Time to source the correct racks/seats. Beat the bushes, their out there. The forward rack also looks to be "modified" with the ends sawed off.
