- 1,156
- Athens, Ga.
I'm mounting a set of 395s on a set of the Hutchinson 20"x10" 20-bolt rims that I think are Caiman and/or MRAP.
I have a leak on two of them and both are right at what I assume is part of a CTIS system. I find it unlikely that the wheel o-ring is leaking in the same place on both rims, so it has to be the CTIS module. I tried replacing the 2 o-rings in the modules with what I had in stock but mine were way thicker than the originals. Tried re-using the originals w/ some sealer and it helped but they still leak.
Does anyone out there have the right o-rings? Since these are old, I don't know what their non compressed thickness was, so I can't order a generic.
Thanks
C
Also, I need one of those weird two piece nuts that is used to attach the rim ring. Anyone have an extra?
Thanks
C
