jimbo66348
- 3
- 18
- Frankfort, n.y.
The point everyone is trying to get across is don't use standard plumbing store stuff. Use the proper DOT spec stuff. The DOT stamp doesn't mean DOT approved, it mean it's built to meet minimum DOT standards for that type of part. No reason to get all fired up.It means the same **** thing. Eaton fittings. Good name, but probably still made abroad. This is not about the terms, approved or certified. This is about somebody wanting to upgrade their truck. If he ever puts a trailer behind it, or just drives it, he must use the correct fittings and lines. With any of these trucks other than the tractors, they are not legal to pull a trailer. It's about safety. I'm frankly surprised about the backlash about safety.
Why are trucks other than tractors not legal to pull a trailer? I have to hear this.It means the same **** thing. Eaton fittings. Good name, but probably still made abroad. This is not about the terms, approved or certified. This is about somebody wanting to upgrade their truck. If he ever puts a trailer behind it, or just drives it, he must use the correct fittings and lines. With any of these trucks other than the tractors, they are not legal to pull a trailer. It's about safety. I'm frankly surprised about the backlash about safety.
Negative. They have a parking brake valve. military 5 ton tractors have the same parking brake valve as a a cargo truck. They just have the tractor valve. The roller linear valve is the same as a push/pull dash mounted tractor valve. It is just incorporated into the handle so that when the emergency brake is pulled it engages that automatically rather than them setting the " parking valve" and forgetting the redundant emergency brake.Just for starters: they have no trolley valve, parking brake valve, nor tractor protection valve. If you are pulling a 10 ton trailer for example, you have to have all of these valves, plus a double check valve in the system, just to be legal.
923&925A2's. Yes, the gladhands have shutoff valves. The issue is you have no way to check nor activate your trailer brakes by themselves, and if a gladhands comes detached, you will lose all braking ability of both the truck and trailer. Any time your going to use a MV for any type of commercial use, you have to bring it up to standards. Outside of antique plates, any vehicle with a gvw over 26,001 lb., needs a CDL. Any combined truck/trailer combination over 26,001 lb. needs a CDL as well. These are federal dot laws that are applicable in every state.
1. Trailer service brakes can be checked by hooking up to the Emergency gladhand temporarily. Hook up to apply and disconnect to release.923&925A2's. Yes, the gladhands have shutoff valves. The issue is you have no way to check nor activate your trailer brakes by themselves, and if a gladhands comes detached, you will lose all braking ability of both the truck and trailer. Any time your going to use a MV for any type of commercial use, you have to bring it up to standards. Outside of antique plates, any vehicle with a gvw over 26,001 lb., needs a CDL. Any combined truck/trailer combination over 26,001 lb. needs a CDL as well. These are federal dot laws that are applicable in every state.
Simple. With a charged trailer, release the trailer brakes using the brake release on the trailer. Hook Service line from trailer to Emergency line on truck. Then pull. If wheels on trailer don't turn then brakes are working. If they do turn then they need adjustment. Unhook trailer Service line and hook to truck Service line. Hook Emergency trailer line to Emergency truck line and roll out. Takes all of 5 minutes.My Dr. For CDL has to follow federal laws. My state, has to follow federal dot rules. My dot tells me it's all federal regulation. My a2 rims are not stamped not for highway use. Please tell me how to do a pull test to check your trailer brakes with these. Trolly valves, tpv's have all been in use and equiped on trucks since the early 70's at the least. Anybody can cut corners anyways they want. I choose not to.
Where is the bit about TPVs being required/retrofitted to pull a trailer?Part 383 - Regulations Section | Federal Motor Carrier Safety Administration
https://www.fmcsa.dot.gov › ... › Parts
The CDL regulations provide that "no person shall operate" a Commercial Motor Vehicle (CMV)s before passing the written and driving tests required for that vehicle (§383.23(a)(1)). Virtually all of the vehicles used for training purposes meet the definition of a CMV, and student drivers must therefore obtain a CDL.
PEOPLE ALSO ASK
What is considered a commercial vehicle?
This is a broad definition, as commercial vehicles may be fleet vehicles, company cars, or other vehicles used for business. Vehicles that are designed to carry more than 15 passengers are considered a commercial vehicle. ... A weight rating of 26,001 pounds or more is always considered commercial.
This is federal law. It is the minimum, that any state can allow. I'm not making things up. I may be wrong at times, but I always strive to be as accurate as possible. I stand by my post. I am correct. Any state can ad to this law, but cannot detract from it.
Screenshot from the Holden M322 trailer Technical Manual...since you know my trailer so well. You'll find the same thing on an M1082 LMTV trailer. It's going to be hard to talk if you keep putting your foot in your mouth.Simple. With a charged trailer, release the trailer brakes using the brake release on the trailer. Hook Service line from trailer to Emergency line on truck. Then pull. If wheels on trailer don't turn then brakes are working.
First, there is no take release on a trailer. Second, once you remove the emergency line, the spring brakes engage. You can't charge the service side to do anything. You should get your facts straight, you'd have a better argument.
