cucvrus
- 9,953
- Jonestown Pennsylvania
Use a test light and see if the red wire on the top of the pump gets 12 volts when the key is on. I doubt it is the shut off. It is more than likely the inside of the injection pump. Do you have the nuts loose at the delivery nozzles? When you crank it over it should at least make the nozzles wet. I had several that did nothing. The inside of the injection pump had issues. Do you have access to a used pump? Before I bought a new one I would put a used injection pump on that is known to work. That may not be an option for you if you don't have one. Report back. I may have a used injection pump from a blown CUCV plow truck engine. You are heading in the right direction. Good Luck.could it be the shutoff solenoid? Or is it more likely the injection pump itself is the issue?
