Self recovery winch: loosing oil through "overpressure" valve
Plasa
345
Italy
Self recovery winch: loosing oil through relief valve
Hello all.
I have a strange problem with my M1078 self recovering winch. On top of the winch drum (behnid the hydraulic motor) there is a small spring loaded valve. I loose all the time oil from this valve, without operating the winch at all. Not many, but when I manually hold open the valve the oil starts to flow and never stops...
My questions are:
- should be oil inside?
- why there is so many oil that drops out?
- where does the oil come? broken gasket / o-ring?
- have anyone a drawing / something to understand how it works?
Thank you and regards from Italy!
Christian
NDT
7,539
Camp Wood/LC, TX
I think the oil is coming from the hydraulic motor. Must have a bad seal which is allowing seepage from the hyd reservoir to the winch gear case.
Plasa
345
Italy
OK, found the drawing. I see a screw (43) and a oring(42). in m1078_TM 9-2320-365-24P.pdf, page 680 Maybe both of then are closing / opening the oil flow to the brake chamber?
Christian
Plasa
345
Italy
Hello again...
Anyone knows what item no. 43 do?
Thank you and sorry if I insist... :)
Christian
Plasa
345
Italy
Hello NDT.
Should be the winch gear case full of oil?
