Suspect pinion seal. Check fluid level in pumpkins.Ok made the first leg. Will check over the truck again. I noticed some spray around the rear axle area. Got to check that out.
Yeah it’s the truck I sent you with the ISO bedOh its that previous submerged truck from govdeals? I know it was used in the last hurricane
That is what is left of your spare tire crane that is welded into the ISO bed. That is where the upper crane rests when it is not in it's used positionThis is the oddshaped piece on the truck bed. Is it for a material handling crane, maybe?
West coast mirrors are available at any parts place. A glass company can replace the glass. Make sure when they put it back together they use black silicone between the glass and frameI will need a driver side mirror, a passenger side windshield. A driver side sear cover. And and and
Yes , the glass is what i needWest coast mirrors are available at any parts place. A glass company can replace the glass. Make sure when they put it back together they use black silicone between the glass and frame
Spend a hundred dollars or two and get a nice air ride seat
I meant the windshield glass. Not the mirror glassYes , the glass is what i need
