This one is mostly for CUCVRus.
The previous owner spliced the wire from the driver side alternator (I assume it's the exciter wire) and ran a bypass to the pass side alternator and cut the black wire , which originally went to that alternator.
I want to take that splice off and see what Issue I am going to find unattended. I assume that one alternator needs to be rebuild and just doesn't put out enough voltage and that someone tied both together.
But I am not sure.
What is your thought on why someone did this change in wiring?
OBTW; reason whyI am doing this is that I have the sneaky suspicion that the the charge system does not put out enough charging power. And i like things to be the way they have been intended to be.
But I am not sure.
