M101A1 Identify parts
unk
San Jose, CA
Looking to identify some parts for my 1968 Case Master M101A1.
Stabilizer leg that fits this bracket?
Source for replacing the reflector?
Thanks
juanprado
3,196
Metairie/La (N'awlins)
That is a common civy reflector with the mounting bracket painted military colors . Pm your address and if you need red or yellow. Glad to pay it forward. Make a donation to ss chaplain fund👍
Your rear frame is tweaked and bent. That bracket does not look like the normal rear stabalizer at first look. Maybe it is, post more pics so we can verify. Shoot pics from underneath also as there should be a catch. Might be best to remove. straighten frame, and bolt on a complete assembly. Any model of m116 or m101 will work. Do not get m105 as they look similiar but much taller trailer and not interchangeable.
Guyfang
27,263
Burgkunstadt, Germany
There are several different types of this leg that possably fit this trailer. The link provided to you by Porkysplace for the TM is you best friend.
Tinstar
2,613
East of Edmond, Oklahoma
Just remove the old bracket and install new leg and the bracket it comes with.
The surplus NOS legs are available on eBay for good prices.
Fun part will be fixing the bent steel on your trailer.
As mentioned, reflectors are DOT standard civilian ones painted OD green.
I found mine on eBay also.
unk
San Jose, CA
Thanks, I have see a few on there. Id like to keep the look, but might end up with an aftermarket type.
unk
San Jose, CA
Thanks!
Welcome to SS , this will come in handy for you , download it to your computer.
TM9-2330-202-14&P.pdf
TM9-2330-202-14&P Op. Unit, Direct, and Gen. Support and Maint. + Parts M101A1,2,3 M116A1, A2E1, M116A3 Trailer.
Appreciate it.
That is a common civy reflector with the mounting bracket painted military colors . Pm your address and if you need red or yellow. Glad to pay it forward. Make a donation to ss chaplain fund
Yeah, looking that way. Going to pull off and try to straighten. Might look at aftermarket options.
Thanks.
Guyfang
27,263
The legs on E-pay, are the right leg for the trailer. Look up the NSN and part number in the TM. Plug them into E-pay. You will get the right part.
