leo4x4
- 6
- 18
- Shadow Hills, CA
those military guys have them as well for $138 on their web site
What are you needing the second compressor for?Compressor charges the system fine. Stuff may be getting by it but I can't complain. I am adding a second air compressor when I do my transmission swap. So I'll just replace the stock one then
Sent from my SM-G935P using Tapatalk
N50011KWhats the part number on these dryers? I cant make it out in the pics
Rebuilding the pure air dryers sometimes just doesnt work out. Lots of documented rebuilds that still have the same purge problems from the dryerI rebuilt mine on my 931 A1 and everything works great, is there a reason that you guys swap them out is it just cause it's cheaper or is there something wrong with the old one?
Yup and then it's swap time. Or when you find a replacement air dryer that is cheaper than a rebuild of the old unit, then it's swap time. YMMV.Rebuilding the pure air dryers sometimes just doesn't work out. Lots of documented rebuilds that still have the same purge problems from the dryer
Service the dryer once a year maybe is the interval. Rebuild should only occur upon failureThanks guys. I think the recommended interval is once a year so I'll either just rebuild it once a year or maybe push it to once every other year since I don't drive my truck a ton.
