Solarizer system mounting questions
DREDnot
447
Phoenix, AZ
Im finally getting around to replacing my solargizer system.
The original was "de-milled" by cutting the wires just under the hood and removing the whole harness/box stuff.
Im wondering if anyone has pics of the units as they were installed originally? If there was a standard routing for the wires or mount location for the converter box. Or were they all just cobbled in however they pleased from unit to unit?
I mounted the panel in its original location and have installed a weatherpac connector at the hood hinge area. Now im looking for the original wiring routing path for the hood mounted solar panel and where was the control box usually mounted?
simp5782
Feo, Fuerte y Formal
9,494
Mason, TN
The control boxes are usually mounted in the battery boxes on all the trucks I have ever seen regardless of their model.
M1078MAN
894
SW Va, Roanoke County
As many of those i installed in the day..we would scew the box to the battery box. panel in the space by the air cleaner stack on non arm. Arm we made a bracket that attached to the existing a piller armor.
let me look for some pics
DREDnot
447
Phoenix, AZ
The box by the door and run your wires thru the slave port hole into the box.
LOL, I went and looked up under the lip of the box and found the old unit.
I'm like..."this is too easy". So I mounted it in the same holes. Later, when reinstalling the battery box lid, I feel it rocking on the lip of the cover and top of the control unit.
Had to drill new holes to move it down a bit.
Ran the harness along the top of the frame rail secured to the vent lines.
Weller
9
Kern County, CA
Thanks for posting the photos. My solar controller is mounted in the same box, but I've modified the wiring so I can quick connect/disconnect to a solar panel on the carport/garage roof. It's an extra step, as I have to remember to disconnect before driving, but batteries remain topped off while she is parked out of the sun.
Weller
9
Kern County, CA
Yup, sorry for the confusion, I have a small 24v charge controller in the box as well, that way the pulsetech has a power source when parked out of the sun. Seeing the photos inspires me to clean up my battery box.
