alpine44
- 17
- 18
- Asheville, NC - Elkton, MD
After sitting for about four month, my M1009 started right up. However, after about 30 seconds the engine rpm increased slightly and then the engine stopped.
No more fire after that. Checked the fuel filter and verified that there is clean fuel coming to the IP. The shutoff solenoid clicks when the ignition is on and receives 12 Volt while cranking. But no fuel is coming out of one of the high pressure lines after loosening the nut at the pump.
Maybe there was an air bubble in the filter and the high pressure side is now vapor locked. Tomorrow, I will take the glow plugs out (to make cranking easier) and see whether I can get fuel out of the high pressure lines at the injectors.
I also read that a plugged return line can cause the IP to quit delivering. Is that correct and how do you troubleshoot that?
It looks like in order to troubleshoot the IP inlet, removal of the intake spider is necessary. Any tips for that?
