daveiaff
- 11
- 8
- Pittsburgh, PA
Rolled the dice on this one, need the cross over manifold. Going to try to start in crate. Questions??? Will starter bolt up without bell housing?, I going to remove valve covers check that each valve is moving, then maybe a bleed down test if I can get right gauges. Then a compression test while cranking. I'll test glow plugs and mock up a harness to fire them up for a few seconds. Thoughts or comments welcomed. Thanks. ![IMG_4930.jpg IMG_4930.jpg](https://www.steelsoldiers.com/data/attachments/522/522709-0de8d6a77422183800a34c28f3b1af49.jpg)
