Grenade Shifter
SasquatchSanta
27
Northern Minnesota
I couldn't resist doing this (see pics)
I tightened it down with a wrench so I can't remove it my hand. I was afraid is I didn't I wouldn't be able to resist handing it to the next cop that stops me and saying, "Here, hold this while I look for the pin!" :lol:
littlebob
27
Baton Rouge LA
You beat me to it. I bought a grenade shift knob from Autozone and put on mine and can't find the pictue I took to post it. It was chrome and I need to paint it.
littlebo
acetomatoco
9
That hokey stuff will not endear you to the LEOs. A grenade in the hand is a shoot to kill ticket here in the liberal Ted Kennedy land.
Barrman
2,245
Giddings, Texas
If you grind it flat a little on the side, your brazing will be better. I made one of those for a guy's M715 last summer. He wanted it so the spoon was facing the dash and the fuse end was next to the steering wheel. He got it.
Bozor1000
Riverside, CA
Re: RE: Grenade Shifter
86M10086.2L said:
Nice looks good, I'm working on brazing some threaded material ora nut tothe bottom of one to retain the fuse assembly for the tranfer case lever in my M1008. But still very cool.
I want to do the same on my M1008
tymbom
NorCal
RE: Re: RE: Grenade Shifter
It's a felony to have even a grenade that doesn't have any guts in it here in California....
SasquatchSanta
27
Northern Minnesota
RE: Gernade Shifter
We silver soldered a nut the size of the gear shift rod on the top of the pineapple where the fuse originally screwed in. There was a hole drilled in the bottem that was capped with arc weld and ground smooth.
I was afraid to keep the old fuse and spoon assembly intact for fear of Canadian customs officials. The inverted pineapple has a good feel to it and it seems to make it easier to shift. I'm going to also rig one on the transfer case shifter.
AJMBLAZER
Paducah, KY
RE: Re: RE: Re: RE: Grenade Shifter
Reason number 3,456,284 I'll never move back to California!
Huh...and the whole time I was living in San Diego I had my grandfather's genuine WWII-pineapple-grenade-deactivated-war-souvenir sitting on my desk.
tymbom
NorCal
I've got one rattling around in my tool box.... I had it on a transfer case shifter once.
