- 850
- 466
- 63
- blairsville ga.
Thanks for the link and thanks Clinto for sharing the idea about Y ing the civi pigtail in going to make that change. Trailer has the LED lights already.Here's another with bed replaced: https://www.steelsoldiers.com/showthread.php?159450-Another-M116-Mule-trailer
Having your own shop sure makes projects go smoother and faster,
Shear 3/8" X 10'
Brake 230 ton 14' bed, 12' clear, will bent 1/4" up to 12' long, 3/8" to 12' and 1/2" to 7'
Plasma 5' X 10' bed, we have cut 18 ga. through 1 1/4" mild steel, It will also do aluminum, Stainless, some alloys and can etch also. Tolerance is .016 and holes should be 1.5 X material thickness but we have done smaller.
Also have a 50 ton iron worker for pinching holes and a horizontal band saw that will cut a 12" square or 12" x 8" rectangle @ 45deg
X2.OK - now you're just bragging (not that there is anything wrong with that ).
WOW! Nice Shop!
That would be complements of MR Zout he's an awesome fabricator, body man and painter, I am not a painter.X2.
Nice '09 as well, looks great pulling the mule hauler.
