DB556
- 129
- 43
- Ambridge, Pa
M35a2 air compressor upgrades
Well its like the title says, I think/know my governor is leaking, and I need to upgrade the compressor for more volume.
Why you ask, I have to run some air tools off road soon. If I'm lucky and find a engine powered compressor cheap soon I can avoid upgrading the compressor.
But it would be good to find if anybody has upgraded their compressor, I've found a few older threads that mentions some bendix compressors that might work but the threads seemed to go nowhere and I didnt want to necro.
https://www.steelsoldiers.com/showthread.php?48206-upgrading-the-LDT-LDS-air-compressor
There were some bendix part numbers for the tru-flo 550 but looking threw the current bendix compressors I dont see a interchange.
As for the air leak, the last few days I found my air pressure dropping fast after parking, previously I could hold pressure for a few days. Now its 5-6 hours.
I was moving my deuce after painting and let the system pressurize and after I parked and shut the engine off I found I could hear the governor pop off 4-5 times
Engine was off and pressure was just under 120psi when I shut off the engine. So I'm guessing the governor needs replaced, Unless you guys think it another componet.
While I'm at it I have a 24v AD-9 clone I'll add to the system since I'll be running some DOT air line.
