Hmmv4me
- 13
- 8
- Carson City, NV
I have a weird issue with my 12 bolt wheel. The tire is aired up and looks good, however, when I check the tire pressure, I get 0 pressure. If I try to add air, if goes from 0 to 40psi in less than a second and when I let the air back out it goes to 0 in the same amount of time. I removed the valve stem to to see if it was clogged, stuck a 2.5" nail in the stem and it hit something hard like rubber. Could the run flat be sitting wrong or something? Is it safe to split the wheel with pressure in the tire?
