Blazer8750
- 0
- 1
- Cincinnati, OH
Acquired an 004A. Put fluids in it. Hooked up batteries. Cranked it over and BANG!!! The pump shaft sheared. Took the cover off the IP and found a mixture of rusty water and diesel in it. I confirmed the shaft is broke by removing the back and checking to see if the vanes turn when the engine turns. They do not.
What should I do now? Have injectors serviced and install remanned pump? Try to locate a shaft and rebuild IP? Part out this unit?
Thanks in advance for your advice?
