Engine temperature scan
Andyrv6av8r
457
Spartanburg,SC
Where is the most accurate place to scan the engine area with a thermal temperature gun to compare to the temperature gauge? Thermostat housing? Radiator hose?
owensexport
81
Chatsworth, CA
The back of the thermostat (Aluminum Crossover pipe), will give you the most realistic indication of engine temperature.
The dash gauge sender is in the front of the head in about the hottest point on the engine.
The senders and gauges are notoriously inaccurate. Since the fan control switch is in the water crossover pipe
close to the thermostat, that is the best way to determine if the engine cooling system is working.
On any of the numerous vehicles I have owned, worked on and driven, if the fan system
cycles on and off when you are driving, I judge the system is working correctly.
If the fan comes on and does not cycle off.... Abort your mission.
911joeblow
68
Utah
Be careful with those IR temp guns. They are wildly inaccurate especially on reflective metal surfaces. Hoses read right but you are reading external temperature vs internal temperature.
Andyrv6av8r
457
Spartanburg,SC
Mine works as advertised with the fan cycling on and off. I replaced my electrical gauge with a mechanical one a while back. However that gauge stopped working and I replaced it again with the same unit. Those two gauges read within 5 degrees of each other so I guess I'm OK.
AAVP7
262
Dortmund, Germany
Also, many people think that the temperature is measured exactly at the laser spot. In reality, those IR guns have a quite large spot in which they measure the average surface temperature. In cheap guns, the diameter of that spot can be 1:5 of the distance (say, you point the gun from 20 inches, then the spot has 4 inches diameter). Better ones have a 1:10 spot. Not really a problem if you know this, but I always laugh when people point a temp gun at some piping at the ceilling (so several feet away) and then declare the temperature to be 82.78 ° F..... ;-)
