What can cause the dipstick to get pushed out?
US6x4
2,248
Wenatchee, WA
It doesn't seem to matter how tightly I compress the rubber base of the oil dipstick (NHC-250), it continually pushes out about 3/8".
My first thought is blow-by or a restricted road draft tube but what else can cause this to happen?
Could the rubber be hardened and not grabbing the tube anymore? What have you all observed on your rigs?
US6x4
2,248
Wenatchee, WA
I need to clean that filter for sure. Is that rubber part available from Cummins or elsewhere?
frank8003
4,985
Ft. Lauderdale, Florida
You brought it up, see TM, goto parts target and use part number and or NSN or FSN and figure it out.
We want you to post what it is you found that corrected the predicament.
There is much knowledge here in the SS database, you could add to that................
We like pictures too and not with tap a whatever either.
at least use the paperclip thingie?
US6x4
2,248
Wenatchee, WA
Those complete dipsticks are cheaper than I expected. Cleaning the draft tube is free so I'll try that first.
WillWagner
2,758
Monrovia, Ca.
Yes to both. A hard stopper can cause it and/or high CC pressure. Try a new stopper first.
US6x4
2,248
Wenatchee, WA
Well, I still haven't gotten a new dipstick yet but I attempted to clean out the breather cap and all the internals are missing. The gasket, the 4 screens, and the baffle are all gone so it wasn't a clogged breather problem...
WillWagner
2,758
Monrovia, Ca.
Let me see if I can find a p/n for the rubber. What was common practice was to buy 2, cut one in half and install the in tact one first, then the lower half of the other stopper. When you put it in, DO NOT tighten it until the screw stops, that is over tightening it. Turn it until there is slight resistance on it then stop.
frank8003
4,985
It was designed to be minor backpressure item
Perhaps put all the missing pieces back
