- 16
- 0
- 0
- Everett/WA
Good Morning all,
Finished fixing up my little MEP-25A 24v DC gen set. Once I put a new fuel line on her (one without a crack normally helps) She fired right up with a little starter fluid, and two pulls.
However, i started getting a milky oil coming out of the governor shaft area into the carb. She was running very well but once she warmed up the oil/fuel leak got worse and I shut her down. Thought I over-serviced the oil reservoir, but when I opened the oil tank plug, I drained very milky fuel soaked oil out of the bottom of the engine.
Tech specs on it:
MEP-25A 24v DC unit - 1968 mfg/and issued
2A016-III engine
Fingers crossed I am not as screwed as I think I am with this little motor.
Ideas?
r/Gunny
Tech specs on it:
2A016-III engine
Ideas?
r/Gunny
