I live in Memphis. 40+ road rage interstate shootings so far this year. They start putting out IEDs i am atleast 1 step aheadHey, simp5782, that sure is a nice little "tap stick" you're carrying on the front of your rig.
You get alot done when you get to play army trucks all the time
Thing looks inbred now, the ol kitty cat is gonna tear up that CumminsPicked up some buffalo boxes and lights from a donkey down in georgia. Moved my headlights out in prep for my grille modification. Added my old puradyn bypass system onto the truck. The BCIII has a bypass filter but i believe the centrifuge will do better and the heater on it will help evaporate other things
Thank you. I use an airless sprayer that pumps directly from the 5 gallon bucket. I've honed the right spray pressure just right.That is a nice looking paint job. HPLV sprayer?
How did you set yours up to keep a reasonable flow? The lowest setting on mine is almost too much. You really have to plan out your spray pattern to keep from getting drips. It’s almost impossible to do a camo pattern with mine.Thank you. I use an airless sprayer that pumps directly from the 5 gallon bucket. I've honed the right spray pressure just right.![]()
My sprayer is set below the prime pressure setting, it's almost on "roller". As for the camo pattern do an outline by hand with the brown then go back to fill in. Repeat with the black in case of any miscalculations.How did you set yours up to keep a reasonable flow? The lowest setting on mine is almost too much. You really have to plan out your spray pattern to keep from getting drips. It’s almost impossible to do a camo pattern with mine.
And with a winch, too, nice score 77 AMG.Actually *got* one this past weekend, and drove it from Springfield MO, to the Eastern part of KY. All on Sunday, about 12 hrs.
