As for the switch, I just pulled one of the blanks out that was on the box already and drilled a hole in it to match the switch. If you look at the pictures you can see a few more blanks off to the right.
As for the question about the current. How I am understanding this is. On one of my other threads (
https://www.steelsoldiers.com/showt...ker-Lamp-Relay-Gets-Hot-when-I-turn-on-lights) when I asked for help troubleshooting a relay what was getting hot, and asked for advice about my starter button not working, but when I opened up the relay and push the relay over to make contact, the starter works. The user NTD told me it was more than likely a relay or fuse in my VIM. I actually opened up the VIM and did continuity test on the fuses but at the point I was going to pull the relays, the idea popped into my head to install the switch.
So, "I THINK" there is a signal that comes from the start button when pushed. That sends a signal to the VIM and the VIM verifies or makes sure that it is OK to start the motor. At which time the VIM allows the signal to go to the starter relay. Once the relay receives the signal, the relay makes contact on the two contacts in which I have put my switch on. Once those two contacts (my switch) (Low amperage at this point still) makes contact it sends a signal to the starter solenoid which in turn makes contact of the high amperage wires that sends power to the starter. AT LEAST I HOPE ANYWAY...LOL..LOL... Sounds good in theory right...lol...If the fukker burns down, I'll sell the crane and tires and update the thread..
So far it's working as it should. I am still waiting for a big lot of fuses. My equipment trailer I just got in, the lights weren't working. So I got back in the panel and pulled a few breakers and moved them around and got it working. My crane didn't work, but trailer lights did. So once I replace all the fuses and relays, I think it will be a good refresher for preventative maintenance on the electronics and all will be fine. I think someone at the yard or a worker at the motor pool took the rear lights off my trailer. Everything on the trailer is LED lights except the rear lights and they were not hooked up. So a quick $200 for someone. But the lights they replaced them with just needed new bulbs and hooked back up properly and they work great now. just not LED.
