cucvrus
- 10,505
- Jonestown Pennsylvania
After all the work you done you could surely change that injection pump at dusk or on a cooler day. Not a real hard job. No specialty tools needed. Just the rebuilt pump and an intake gasket set for a J code 6.2 diesel. A beginner can do it easily in 6 hours. Good Luck. But changing the injection pump is fairly easy and paying someone to do it is expensive when you don't have the money. Hardest part I know of is getting the injection lines reattached in the tin formed mounts on the intake studs/bolts. That ain't that hard if you leave the nozzle nuts unattached. Good Luck. Be Safe.
