- 3,201
- 3,183
- NORTH (Canada)
LDS engine
I was thinking "fuel starvation". That is why I kept her coasting in gear....keep that IP spinning. I was not sure if she would re-start if I pulled over to the side of the road.
- spin on primary and secondary fuel filters, new this Spring
- gap between HH and IP body is moist; I guess I will be doing O rings in the future. But would a hardened O-ring at the HH alone cause such symptoms? Normally it is just fuel leaking out, isn't it? Changing the O-rings is a job I do not want to do unless I have to. Done it at the previous engine. I just do not like the HH.
- no fuel leaks that I can see
- running #2 diesel only
- new aluminium A3 fuel tank last fall; squeaky clean; cleaned in-tank-pump at the same time, it is running. I did not replace the pump hose, though.
I searched for similar issues - and found some posts, so this does happen to others - but there was no conclusive evidence as to what the cause was (or it was a cause that does not apply here, such as rusted, dirty canister filter).
Any thoughts? Recent power steering install...maybe I kinked a fuel line? Gotta check...
- starts as soon as you touch the button
- Ran fine all year, she is being driven a lot (when not down for upgrades or maintenance)
- Yesterday, four hour trail ride, no hiccups
- On the way home, in 5th at about 1700 rpm it suddenly felt as if I lifted my foot off the throttle completely. No power. In fact, depressing the clutch sees the engine shut right off. After a few seconds (5-10) of coasting in gear, keeping the engine spinning, depressing the fuel pedal causes the engine to respond normally, as if nothing ever happened.
- Repeat episode, seemingly at random.
- 5th gear at 1700-2000 rpm seems to "trigger" it more, 4th at governor....not one episode. Not sure if that means anything.
- When she runs, she runs like a bat from ****. More power than you'd need.
